singleslammer251 »
https://forums.nicoclub.com/singleslammer251-u119737.html
Thu Apr 23, 2009 6:00 pm
i had this same problem mine wouldnt turn over cuz it was 180 degrees off but that isnt the cam gear. the cam gear has a notch in it so it cant be turned. in order to set timing take off the valve cover make sure the two different colored links are on one dot on the cam gear and one dot on the crank gear now turn the engine with a breaker bar till the red hash mark on the crank pulley is lined up with the pointer on the timing cover and the cam gear notch is pointing up. you are now at tdc being 180 degrees off means you dist gear is flipped, take out your oil pump and take that dist drive shaft out and put it back in to where the notch that goes into the oil pump is vertical while it is fully pushed in, now set the oil pump back on to the shaft in and set the dist in with out the cap and see if it is pointing at spark plug one which is the lower right one if looking at it from driver side fender, if it is pointing up to the left its flipped 180 then just turn the dist shaft around again while it is still on tdc. then plug in your wires and set the timing.
