JNM240 »
https://forums.nicoclub.com/jnm240-u395.html
Fri Aug 04, 2006 6:05 pm
Check to make sure you are actually getting spark for starters. If yes, and you are getting fuel, then reset the motor to TDC on compression stroke, pull the valve cover and the crank pulley and make sure the keyway on the cam is pointing at 3 o'clock, and the crank straight up, and the rotor is facing the notch on the lip of the distributor indicating #1 cylinder. My bet is, if you just put it back together, the distributor is a tooth or more off, maybe even 180 degrees off (firing on BDC). Remember that you can correct this by removing both the distributor and the oil pump, aligning their respective marks, and reinstalling. As long as the motor is still at TDC on the compression stroke, everything will be fine.
