mjracine7 »
https://forums.nicoclub.com/mjracine7-u189737.html
Thu Aug 25, 2011 12:40 pm
im new to the forum and i figured i would share this story with you.
my 1990 d21 has been making a horrid noise on every start up and while driving coming from the what sounded like the timing chain. i removed the valve cover to inspect it and found the slack guide was completely missing. i immediately ordered a new chain set. 2 months and about 4k miles later i decide the noise im hearing is getting worse and worse so i decide today is a good day to finally fix my truck. removed the oil pan..... the slack guide was in like 50 pieces jingling around inside the pan so i loled and moved on to removing the front engine cover, as im removing the cover i hear something fall to the ground.... what fell to the ground was the timing chain tensioner guide, guide bolt, and tensioner pin and spring. i had just driven this truck over 100mph on the highway this morning. LOL looks as if the bolt backed out and is now rounded off so i cant use it. good old nissan dealer wont have one till 10am tomorrow. stuck waiting on a $4 part.
