KA24E Ticking Noise on Exhaust Side
RustyShackleford
Car: Red Piggy w/Black Meshies
I have a 90 KA24E 208k stock and when I start the car and drive I can hear a ticking noise near the exhaust side somewhere between the exhaust manifold and the cat. It ticks around 1500 to 3000 rpm and then it stops and it only does it until the car is driven for about 10 minutes. It's louder under load but if I rev in neutral it's faint. It's not very loud though.
Phil2049
Car: 1990 Nissan 240SX
maybe youre low on oil?
BLKONBLKS14
Car: 1995 240sx
check out the TSB(tech. service bulletin) on timing chain guides, believe someone posted a how to on it. They some time get to where they make a ticking noise from around the top TC cover or valve cover.little further back in this section you should find it. hope this helps
RustyShackleford
I'm pretty sure I'm not low on oil but I'll check it. I seriously doubt it's the timing chain because it's a lot quieter and it's not as rampant.
sx moneypit
Car: 2010 Nissan 370Z
1986 Toyota MR2
Sounds like you got an exhaust leak.
RustyShackleford
I figured it out guys that's for all the input. It was the hydraulic lifters. Thanks a lot haha
sx moneypit
1986 Toyota MR2
