ka24e throttle body?
Indecisive
Car: 1987 200sx Turbo
Hey everybody, I did a search but couldn't find an an answer.
Will the throttle body off of a ka24e work on the ca18det? I know the ka24de throttle body will work, but what about the ka24e?
The reason I ask is because I've got a ka24e throttle body sitting on my ca18et, and would like to upgrade the ca18det throttle body to something bigger. Hoping somebody could help.
rico05
Car: 1992 RMS13 w/ CA18DET
I'm running a KA24E. Just flip it upside down and there ya go. It is a little bigger than the CA intake manfold, so you will want to port the intake.
splintercell
Car: 1989 Nissan 240sx HB CA18DET
1991 Nissan Silvia Q's SR20DE ITB's
rico05 wrote:I'm running a KA24E. Just flip it upside down and there ya go. It is a little bigger than the CA intake manfold, so you will want to port the intake.
i did the same thing and capped the nipples with rubber caps. works fine
Indecisive
Awesome. Just the answer I was hoping for. Thanks a lot guys.
rico05
The water lines going uder the TB will stick straight up, so I cut those off. It's baller status too: It says Hitachi on top of the TB now. Hells yeah.
splintercell
rico05 wrote:The water lines going uder the TB will stick straight up, so I cut those off. It's baller status too: It says Hitachi on top of the TB now. Hells yeah.
I should have done that, but i just bent them over and capped them.
JNM240
Car: 90 Coupe, 90 Hatch (CA18DET)
So is the TPS compatible? Or do you need to reuse your CA TPS?
splintercell
i dont think i changed mine. i think we used the same tps.
DALAZ_68
Car: 90' 240sx CA18det
iu thought u had to take apart the assembly and fit the TPS mounting section to the KA TB...bolts right in...and so willl the butterfly from the KA to the CA assembly...or am i just mixed up and making stuff complicated ...
would a DE CA TB be compatible with a DET TB...
