Ka24e
TortureMySoul
Car: 1989/1993 Nissan 240sx
Just wondering. where's the best place on the sohc ka24e to bolt up your chains when pulling it? Also I was wondering if it was possible to pull the wiring harness and swap the ecu's when i drop my Ka24de dohc in? I would prefer not to have to cut and soder the wires back together....
ScrapnSidwayz
Car: My damn S13 is a fuggin money pithole
when i pulled my ka24e i just wrapped a chain under and around the intake mani and wrapped it under and around the exhaust mani.
also i have seen people bolt one chain to the front of the head and bolt a chain to the back of the head. but... im not sure how safe that is. i did try this method though when i had to remove the engine mounts and it seemed to work fine.
hope this helps
ScrapnSidwayz
also im not sure about the ecu's i pulled my ka24e for a fresh built ka24e so i didnt have to mess with the harness
TortureMySoul
I pulled the wiring harness on both my sohc and my dohc, the plugs into the ecu's match up but, if i used the ecu from the sohc for the dohc wouldn't it mess up or not run correctly? and thank you for the info on where to mout up the chains.
TortureMySoul
Update- Pulled the sohc with no problem. Hooked the chains to the exhast and intake manifold. now i'm about to pull a Dohc anyone have tips on pulling and disconnecting that?
