if your miss firing at .030 its not the spark plugs fult, bad ignition wires or weak distributor might be a cuseftrs13 wrote:do you gap up the supra plugs ... I got a set of stockers, couldnt find the ngk, and they were gapped at .020, so I gapped them up to .030, and Im misfiring terribly in boost.
should I have just left them at stock gap, or just find the ngk and gap those up as well, or leave them alone at .020?
Checkered-Member wrote:if your miss firing at .030 its not the spark plugs fult, bad ignition wires or weak distributor might be a cuse
ftrs13 wrote:yeah, Im watching for it, I realize that its a problem with the T3 internally gated, but I havent had any problems yet, Im going to redo the plugs tonight, and see where that gets me. I also have a new set of 7mm bosch plug wires, so Ill be doing that up tonight, and see where that gets me
