Boosting your car on the stock injectors, untuned, and with a stock fuel pump is idiotic. Stop boosting or you will blow your motor.
You really should do a compression check and make sure you dont already have cracked ringlands.
ka24monster wrote: Even N/A bosch plugs make it run like crap and at .38 your probably blowing out spark under boost!
The brand of spark plug alone does not make an engine run bad. Incorrect gap and heat ranges make the car run bad. Your advice about the NGK BK7RE's @ about .30 is dead on, those are the most widely used and best all around plugs for a ka-t.
