sstomek »
https://forums.nicoclub.com/sstomek-u31323.html
Sat Oct 20, 2007 12:45 pm
After replacing a bad intake manifold gasket that caused a vacuum leak in my car, we turn the car on and all if good. Car sounds like it should, but then after about 5 seconds the car just dies.
When i unplug the MAF the car stays on without a problem and idles at 700 rpm.
Car has a SAFC hooked up. We replaced the alternator and checked to make sure it is running, which it is. Checked the alternator fuse also and its ok.
Anyone have this type of problem before?
Thanks in advance,
Tomek
EDIT: It was the IN and OUT settings on the SAFC. I changed them to 1 IN and 6 OUT and it's back to normal now. YAY!
Modified by sstomek at 4:01 PM 10/20/2007
