Okay so I am doing a ka24e swap in a datsun 720 I followed the wiring on this page:
http://community.ratsun.net/topic/537-h ... -anything/
I wired it how it said except the fuel pump positive i noticed was pin # 104 according to the pinout and # 106 wasn't black and pink so i assume that was a mistake.
The starter wont engage when I turn the key and my fuel pump runs while the truck is off and turns off when the ignition is in the on position. I believe I am using the correct relays they have two 87 pins but none are 87a so I believe it will be for sure a normally open relay? Not too sure where i could have gone wrong if anyone has any suggestions i'll listen to anything.
Thanks
Nathyne
