kyle1911 »
https://forums.nicoclub.com/kyle1911-u12189.html
Mon Nov 29, 2004 6:33 pm
I cannot get it to misfire without load being put on the motor, so the power balance test doesnt work very well in this case
No tune up recently, I replaced the alternater yesterday cause it appeared to be loosing power while i was driving causing it not to spark. I also put on new plug wires and rotor cap, eye balled the timing.
The problem is more consistant when the engine is warmed up.
When I am coasting and get on the accel about 25% it goes dead as in no combustion than jumps to life with less power than ever.it stumbles when i am driving and backfires occasionally when i start to accel while moving.
I also checked vac lines for leaks with no sucess,.
