Ka24e starts then dies HELP!!!
TrufflesSmile
I just swapped a ka24e from a hard body, into my 89 240 and I got everything connected correctly swapped the intake on changed the oil pan and stater. Now I go to start it and it cranks it turns on and then dies immediately :wtf2: if i'm on the gas it will stay on but it's super rough Idk what to do. I've checked the injectors, maf, iac valve, tps, nothing is working i'm extremely confused. :mad: :mad: :mad:
lexcrob
Car: I get a different ride faster than I could update this.
After running it for a bit or even just leaving key on for a bit. Check the engine codes. That computer will tell you what it has problems with keeping it from running.
Good luck,
rob
