KA24E start problems, getting highly FRUSTRATED!!!!
cleancoupe
Car: 1990 nissan 240sx coupe
i have a 1990 240 coupe, ka24e the car runs good and starts prefectly fine when the motor is cold but if i drive the car for like 30 min or more then park it and go into a store and come out 20 min later car wont start, if i pull over to just get gas (5 min) it will start fine. ive replaced coolant temp sensor coolant temp sensor pigtail connector off harness, all 4 fuel injectors, fuel filter, spark plugs, and gutted my cat due to bogging issue but still have no start problem. please help i am getting highly frustrated. thanks
driftneil
Car: A pile of cars.
Its most likely your coil....When they heat up they usually wont start till they cool down.
cleancoupe
alright thanks ill check that out i was planning on checking it because it sounds like i have an interminent miss also
driftneil
cleancoupe wrote:alright thanks ill check that out i was planning on checking it because it sounds like i have an interminent miss also
Intermittent is usually the starter solenoid....
cleancoupe
Thanks for the suggestions it turned out to be my fuel pump replaced it and now she starts every time.
