I did check and there is voltage at the connector.bradt wrote:if you changed out the IACV, and nothing happens, run a voltage check. Make sure it is operating within spec.
How do I recalibrate the tps?KUILLIN_DRIFTER wrote:i'm thinking your tps needs to be recalibrated.
