jonathan1173 »
https://forums.nicoclub.com/jonathan1173-u146856.html
Wed Nov 04, 2009 11:43 pm
I did have to rotate the cam a bit when replacing broken chain. I lined marks top and bottom, set to TDC, and set oil pump and distributor to#1.I cranked and it wouldnt start! That is when I started adjusting teeth.I do have the valve cover just sitting on top of head with two bolts to hold it down temporarily. Do you suppose air/vac leak getting into valvecover could affect timing, power? I'll check with vac gauge and reinstall valvecover seal, then checkI do have the truck idling smoothly, and running, but with hesitation on acceleration, with distributor all the way advanced. I have it narrowed down to two teeth: Left to right, 4 different teeth, I'm on #3. If I put it on 1 or 4, it doesnt start. 2 or 3 it runs, but hesitates, with dist advanced all the way. If I retard dist, it wont start on 2 or 3, much less 1 or 4.
