i too have this issue ill rip through gear 1st......2nd.....brrrrrrrnnnnnnnnn tach will be at around 5k i push in the clutch and at 3k itll rev again and put in 3rd and slowly climb to 4th and 5thmick wrote:You can destroy the cat/foul the spark plugs by running rich
were you asking me sorry?saipan240 wrote:hi... I think we have the same problem. how's your spark plugs? does it warn out fast?
ok look today i took the car on a long drive and high rpm it boggs down to 3k then its kool but if i down shift sometimes itll red line then wen i go from lets say 3rd and shift alil above 5k then 4th and i get to 5k and nada my foot all the way to the floor and nada like if i turnd my car off on the highway then as my foot is still down the tach neddle is @ 3k and car responds again then 5th and usaully in 5th im doing 65-70ish mph@ 3k RPM wats my issue then? VSS? EGR?liquid_cool wrote:your in the wrong ballpark for this one guys.......this is a air/fuel issue....
lets start by eliminating the fuel injectors all together...unbolt the rail from the intake manifold...disconnect the coil wire(for safty)...have a buddy turn the key to the on position..not cranking it..just on so the fuel pump primes...look at the base of the injectors..if there is a fuel leak..o rings are bad..replace...now step 2 of this test.....have your buddy crank the car over...are the injectors spraying?....if they are..you just eliminated the injectors.....lets move on!
O2 sensor....just replace this anyways..there 15 bucks and need to be replaced anyways every 30k..
last but not least...test your maf!..and make shure your maf's electrical plug has a really good connection...you will have to follow the factory service manuals test procedure for this..there are many links to the FSM on nicco..good luck
test you MAF first....they do fail and can couse this issue....there is another few sensors that would allso couse this..and they can be bypassed..and those are the 4th and 5th gear sensores that tell the ecu to limit fuel at certian rpms..its like a govoner system for the 5speed...you will have to use niccos search button to find the procedure for the bypass..as i have not done this...i do know you can bypass it with one of two ways..ither swapping in a automatic ecu..or by clipping certian wires..good luckdat925stunna wrote:
