ezb57e »
https://forums.nicoclub.com/ezb57e-u238040.html
Sat Jul 05, 2014 4:12 pm
Like so many problems folks have, if there was some data showing what was good and what was not, better suggestions could be made here. It may not have anything to do with it, but there was a bad ground splice on these (and other trucks) which created a poor signal from the TPS, ETS and TPS. It is in a black wire, in the main harness near #4 injector. The original just used a brass crimp connector, we soldered it up.
If you have a data stream, you can watch the values of these components while wiggling the harness and watching if the values change.
