180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon May 29, 2006 9:15 pm
this is from memory so bear with me.
you should see 2 rocker shafts. They go through the rocker arms. On the rocker shafts, you should see a series of 5 bolts each.
4 8 10 6 23 7 9 5 1
that's the order in wich you remove the bolts on the rocker shafts. Loosening the bolts should be done in a few steps, not all at once.
There are little metal retainers on the rocker arms that are attached to the rocker shafts. Take them off and remember their order.
slide the rocker arms off the shafts but keep them with the opening parallel to the ground. If you turn them over flat with the O facing up, you're gonna have air enter them. Might want to have a pan filled with oil to put them in. Remember the order in which they go in by the way otherwise you'll have fun measuring them out with feeler gauges for the next couple hours with a tear and a frown on your face.
install is the reverse order, minus the emo part and tipping the rocker arms on their back so the O is facing up (bad news).
