Jayson240 »
https://forums.nicoclub.com/jayson240-u138999.html
Thu Jul 23, 2009 6:23 am
The same thing happens to me. 92' kade.
i can tell you that it's not the fuel pump, injectors, cap, rotor, spark plug, wires, fuel filter, cat, or the timing. the head was just rebuilt as well.
what i'm suspicious of are the maf, some sort of short circuit, tps.
i was reading another forum and someone mentioned something about checking the transmission switch for a short. what is a transmission switch?
EDIT: i just talked to a friend and he said it could be the sensor inside the distributor. gonna check it out later and i'll post the results.
Modified by Jayson240 at 9:35 AM 7/23/2009
