formsim »
https://forums.nicoclub.com/formsim-u127356.html
Thu Apr 09, 2009 9:52 am
New to nico but have been 'searching' forums to answer my questions for months and finally stumped.
Long story short i bought a 240 90' fast back. Stripped it , then decided to strip and rebuild the top half of the motor because of a few issues found.
Moved the battery to the backDid a full emissions removalremoved clutch fanTook the head off and replaced the valve sealsRemoved swirl valves and sealed themreplaced all the gasketscut a ebay intake pipe and attached a maf adapter + filter
All of the above appears done correctly because the car idles (after a few problems that i resolved) at ~900-1100 fairly smooth with no vacuum leaks that i can find but here lies the problem.
Idles only when the MAF sensor is either unplugged or plugged in but not in line with the TB.
I measured the voltage and i'm getting .85 when not in line and the engine is idling. Soon as i put it in front of the TB it rises to the expected 1.0-1.1 but the motor shuts off.Isn't it suppose to be at ~1.0....
If i blow into the front of the maf while it is not in line engine smooths out. If i give it WOT while inline it hits redline no problem but coughs as soon as it gets to 1.5k and then shuts off again.
I even re grounded the sensor thinking i had a bad ground.Checked the TPS location as well to no avail.
I'm pretty sure this MAF has no issues (was fine before the rebuild) so anyone have any ideas what i could be doing wrong? Isn't voltage suppose to be at ~1.1 at idle anyway...
btw
Nico
