So I have a few questions regarding my engine rebuild but first a little history on the engine itself. The engine overheated and cylinder 4 was getting no cumbustion. I tore the motor down to the bare block and cylinders number 2 and 4 had the piston rings stuck to the piston. Also almost all the rod and crank bearings were down to the copper and there was a lot of black oily dirt in there.
I'm gonna replace the bearings, rings, gaskets and seals and I have the head in a machine shop. A buddy of mine told me to buy new pistons since the old pistons might be out of roundness due to the engine overheat. He also told me that I should have the blocks cylinder walls bored .20 over and the crank cut the same. Is this necessary? It would have me go way over budget. Can I just have the pistons checked for roundness at a machine shop?
Also, if I do end up having to buy pistons what are opinions on ebay pistons compared to lets say federal mogul pistons which is a reputable brand?
The goal of this build is a reliable dd, no drifting no track racing. Ill be buying parts soon so any advice will be appreciated.
Ill post up pics later since im on my phone.
