KA24E question
crazybone96
Car: 92 nissan stanza
i have a 92 stanza race car and need an engine block, and im trying to figure out if any ka24e block will fit, or which specific models i can get one out of. hard to find stanzas where im from, so trying to open up my options. any help would be appreicated, even a link to a page, or another topic i may have missed while searching. thanks
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
I know any KA24e ECU will work on any other KA24e.
As far as blocks I'd imagine the only difference in bottom end would mostly be in the oil pan.
Pickups are rear sump and 240's are front sump.
The direction of the inlet for heater hose my differ as well.
If you have pictures of a FWD block I might spot something, but heads should be identical, Front cover might be different on the FWD depending on where the dizzy needs to be. but pretty sure RWD front covers are the same.
So really IDK.
I do have a 240sx block to stare at and compare too tho.
