ka24e problems....HELP!
rapom
Car: 1989 240SX Hatchback
ok first off a little about the car, its a 89 240 all stock, 4 speed manual.got the car ffrom my uncle after he almost had it melted down as scrap, so it had not ran in about 4 years or so, wasn't getting any fuel so i changed the pump and it ran like a champ, then it started to loose alot of power and wont rev/idle right, now it will start and idle, had to crank idle to about 1200 because when you put it in gear it dives down to about 250-350. but while it runs it is very rough and will not go past 4000rpm, barely gets there, but if i unhook either the plug wire or the injector cable to the 1st cyl. the idle smooths right out and rises about 300-400 rpm , i have tried all the basic things i can think of, canged the plugs and wires, my cousin changed the injectors, he says it is the fuel rail, but i don't know. pulled the ecu and getting the 55 code, so thats ok, i just wanted to post on here because i would really like to get it running, really don't want to be forced to do a swap. any ideas?
rapom
also forgot to mention, there is a noise on the exaust side in that cyl, kind of like air just blowing through, in a steady pace
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
those four speed 240s are very jdm rare. have you tried doin a compression test? its not the fuel rail. check your voltage at the injectors, also use a noid lite. check the condition of the wires leading to the injectors and also to the CKP(in the distributor) start with all that
rapom
sorry ment auto, my bad!ok thanks ill try that
s13princess
injectors!!
