nuts510 wrote:there are two different piston compression ratios in the single cam car. If you use the piston from the 90 model your compression ratio will be around 10 1/2 may be a touch more...
Not so...the correct #s are 11.1 for the 8.6: SOHC pistons, and ~11.6:1 for the 9.1:1 SOHC pistons - See below.
GnarKiller wrote:Are you sure those are the right compression ratios?
How do you know...
Do the math...
http://www.ariaspistons.com/sportnissan.htm - Lists Head cc (46cc), deck height (0.0001, since 0.0 does not work in the calulators), bore and stroke, and head gasket thickness (~0.045, or ~1.2mm...standard for the KA).
9.1:1 SOHC pistons are known to have a 2.8cc dish, so use "-2.8"
8.6:1 SOHC piston have a 6cc dish.
Plug those #s into here:
http://www.campbellenterprises...s.htm
And you'll get ~11.1 and ~11.6
Easy stuff.
- Brian
