kouki-guy »
https://forums.nicoclub.com/kouki-guy-u18475.html
Tue Mar 09, 2010 1:45 pm
are u using a nissan thermostat? aftermarket (autozone etc) tend to suck, and did u bleed all the air from the coolant system?
i have a ka24e as well, just tried to change my t-stat today and decided i would flush the coolant instead, what i do to bleed is jack the front end as high as i can. then open the radiator cap and pour in coolant, squeeze the upper hose to suck in the coolant and to let out some air, then run the engine while squeezing upper hose to burp air and continuously add coolant after pushing the throttle cable (since this sucks in the coolant), after about 20-30 min u should be free of air.
