Ka24e overhaul
xsean415
My car makes a bad rattling sound, i think i blew something in the motor... Theres a loss in performance.. The car still runs, but makes a really bad rattling sound....How much should i expect to get my engine overhaul at a shop? Would it be cheaper to just swap in another ka24.. i know most of u would suggest a sr20 but i dont got the $$$ as of now =(
drjohn
It's possible that you may have a loose timing chain or broken guides and the chain jumped timing. That may explain the noise and the lack of power.
xsean415
i turned the car on today and white smoke came out.....so that def. means i blew something right? the car barely runs, it will start and stuff, but i doubt i can drive it for a mile....:(
Bay Dog
Car: 1985 300z Turbo
Yeah, it is probably done. Check your oil to see what color it is, if it is 'milkshake' colored, then you are in for some ugliness. Dr. John, it's yours from here, but I was told that once this happens, the internals of the engine are pretty much shot and your better off just to replace the engine. This is what I am having done as once the antifreeze got into the oil, it spun a bearing which in turn threw a rod. The knocking was HORRIBLE!
However, if the oil is not the milkshake color, then it could be something else not quite as costly???
Good luck!!!!
