KA24E Or KA24De
LoserbabyS13
Car: 1989 240sx w/ CA18DET and 2003 WRX
I have serched for this and cant find what I am looking for. I am buying a high mileage s13 to re-build and turbo. I am wondering if I should re-build the motor in it (KA24E) or buy a cheap KA24DE and build that? I also would like to know if the MAF sensor from an s14 will work on an s13 with the KA24E and the KA24DE motors?
TurboKA37
both of those engines have been proven to hold boost pretty well. i like the DE a little bit more because its a more modern engine and theres also more aftermarket support for the DE. Im not sure on the other questions so i cant answer those
Altiman94
Car: 1989 Nissan 240SX
The sohc has lower compression than the dohc. I would probably rebuild what's in the car because it's already there and you won't have to mess with wiring harnesses and such if you were to do a dohc swap. The ka24e will hold fine to boost, and many, many members have turboed them successfully w/o any adverse effects.
240marcuSX
Car: E34 525i
E46 M3
i agree with altiman, If you have the money id either A) turbo/rebuild the EB) keep the E stock, and completely rebuild a DE before you put it in and boost it.
andrave
Car: 1989 Nissan 240SX Coupe
I'm keeping my E stock and slowly rebuilding a DE for turbo use.and then I'm gonna keep the E around in case I blow the DE so I have a back up.
90lkn4swp
Car: putting rounds down range / and gettin back home so i can drive again
Altiman94 wrote:The sohc has lower compression than the dohc.
If im not mistaken i believe the E has a higher C/R mabye its just after you swap the pistons to the DEbut i think it was something like 10.5-11/1 although i maybe wrong.
EricZ103
Car: cars, duh
90lkn4swp you have it backwards, e pistons in a de make a higher compression ratio. Altimaman was correct about stock cr's too.
90lkn4swp
Yeah if you swap late model 89 pistons to the DE you get 11.7/1
90lkn4swp
loserbaby im also gonna turbo a ka although i have just read about the de head fitting on the e block so im still not ready to start buying parts for a kit but mabye you should read up on some posts about this head swap looks good to me but then again i dont know what im doing:confused:
90lkn4swp
this is where i heard about the swap
http://www.nissaninfiniticlub....ber=1
Altiman94
I've seen that as well. I definitely would keep the E. Buy another one and rebuild that for turbo. It would make the swap so much easier. What does everyone have against the sohc?
LoserbabyS13
Here are pics of the s13 I bought. 89 XE.
http://community.webshots.com/...kQVLT
Thanks for all of the response's. I am still wondering if anyone knows if the s14 maf will work on the sohc s13 ka. Thanks in advanced.
240_2NR
Car: DayDreaming
i thought if u have a SOHC 240sx to swap it for a DOHC u need to change the power steering lines? my friend has a 89 240 and he is planning to build up a DOHC and then swap the SOHC but he wasnt sure if he should do it, the DOHC's has piston oil squirters and i think a better aftermarket support, feel free to correct me
