180fan wrote:it oils the chain. without that, you'll have really low oil pressure.
bumping ~6 hours after your initial post is really poor nettiqutte. get over it.
well excuse me for being in a slight hurry not having a lot of patience, i dont have much time during the week to get things done, a harmless bump and the sooner someone can answer the faster i can get more things done. its not like im starting more threads on the same topic or constantly bumping the thread all day, im keeping it in my own, and id say 6hrs is a decent amount of time thank you very much....no need to get panties in a bunch and say "get over it"
anyways, how does it oil the chain when no oil ever goes out of it normally?
i took a look at it again on the good block, and i noticed there are no holes what so ever on the pin, but did notice 2 scratch marks that i would assume the timing chain caused on it. the pin with the timing chain installed sits in between the 2 chains (not 2 seperate chains, but the two halves i should say), but not touching either one. im assuming the chain marks on it are from when the timing chain guides broke in the past
or it could serve a purpose to stop the chains from hitting each other as the tensioner loosens and tightens? but i dont think the chain ever gets that much slack...mysteries hehe
Modified by mutiny at 1:33 AM 8/2/2007
