KA24E Oil Pan Gasket R&R
240Dave
Car: NASCAR, vehicle mods
I am a pretty decent tech and I feel like I need to say that before I ask this question...:), but one thing I have learn over the years about car repair is that there is always someone out there that knows more than you. I did a total rebuild on this motor about 21,000 ago. It was bored 20 over due to the #2 cylinder oil control ring quitting. Everything is pretty much stock except for the injectors and airfilter. And it runs like a bat out of hell...BUT it has developed a bad oil leak. What I need to know is does anyone have a FACTORY SM (mine has been lost in a move) that details the replacement of the oil pan gasket without engine removal. They always detail little tricks that the factory knows about or if any of you guys might know. I am sure that the motor will have to come off of the mounts but likew how far, what, if anything at the back of the motor near the firewall needs to be moved or removed to allow the motor to tilt backwards and up? Just trying to a little homework and find out the shortcuts ahead of time. All input will be greatly appreciated. Thanks!:ylsuper
singlecamhonduhkilla
Car: learning all i can about this car.. some street racing.. etc..
LOL THATS WHAT I NEED TO KNOW.. I NEED TO TAKE OUT MY OILPAN.. BUT I DONT WANNA TAKE OUT THE ENGINE TO GET TO IT.. AND I SURE DONT WANNA TAKE OFF MY SUSPENSION EITHER... JOE
1dollar240
i have a factory service manual in pdf format saved on my computer. its like 18 megs or something. i havent looked through it to find out about your question so i dont know if the answer is in there.
240Dave
Thanks for the info and it would be great if you send it to me! Since it is large and my email capacity is only about 6 meg, do you know if there is a way to post it to the board? Maybe break it up into 3 - 5 messages or attachments? This is a godsend...thanks guy. By the way, last night I dropped the front sway-bar, unbolted the motor mounts, jacked the motor up by the crank pulley, loosened the torsional brackets that connect the block to the bellhousing, loosened the pan bolts and it came right off. But I could still really use the manual for other S@#*. Thanks again and let me know if there is anything I can do for you.
1dollar240
whats your email address? i can break it up i think, unless someone on the board will host it?
float_6969
I've done 3 timing chain replacements and so I've removed the oil pan 3 times. First of all, there isnt' a gasket. You just have to use RTV. You will have to support the motor somehow (I put a jack under the transmission) and then disconnect the motor mounts. then You'll need to remove the anti-sway bar and T/C rods. (at least unhook them from the lower control arm) Then drop the lower sub-frame. 2 bolts on each side. It's still a pain to get to the bolts on the oil pan, but at least you can actually get to them. If that doesn't make sense, lemme know and I'll explain it in better detail.
ricebike
2002 Quest
2005 Altima
that's weird: i got a oil pan gasket from FELPRO
bj180sx
Car: cars
Yes there is a gasket. I have one from courtesy nissan. It was like $10. No easier way than to pull the engine bro.
Bomexrps13
Car: Alarms Multimedia, MobileElectronics, Custom Fiberglass Fabrication, 14 years of AutoSecurity and Ca
I too need to dro my oil pan the gasket needs to be resealed. I got as far as dropping the front stabilizer bar and all the bolts aroung the oil pan are all out now. I can get the pan out stll. The 1989 240sx service manual says to take off nuts off the sid members too. What are he side members? Whats next HELP please...Have not driven my car for a week because the mechanic that replaced my engine not only 4 got 2 put my heat shield back on and burnt my spark plug wires on the way home. he reason why I am doingthe oil pan gasktmyself is that he 4 go 2 liquid gasket the front half rubber disc that sit betwen the block and the valve cover andit fell in the engine I had to fish it out...ARGH!!! please help its frustrating 2 me..[FONT=courier new][PHP]
Bomexrps13
hello?
