liquid_cool »
https://forums.nicoclub.com/liquid-cool-u100587.html
Fri Feb 20, 2009 6:05 pm
check the filter!..if the oil sending unit is leaking that would be the first one ive ever herd of in my life failing..try to tighten up the oil filter..if its tight..think back to when your last change was done and are you using a high flow filter or a regular one...it might be time to replace that..allso..the filter attaches to a sort of adapter..check to see if ya blew the seal on that...if ya did..you can make one or go buy one..its an easy fix ither way..good luck.
