gniknave »
https://forums.nicoclub.com/gniknave-u19269.html
Sun Apr 24, 2005 11:43 am
I hate to say it, but that's the exact sound/symptoms I heard before having my timing chain & guides replaced. Did they replace the guides when the timing chain was replaced? It's important that they did so.
You should remove your valve cover again and check to see if you can see the drivers side guide (mine was pretty much gone). If you can see it, then check to see if you can tell whether or not it's metal backed. If not, then that may be your problem.
