KA24E motor that won't stay running. desperate for help.
formalyDSM
Car: 1989 240 SX with An RB20
Hey yall. my motor will start, stay running about 3 seconds then die. if i tap the gas pedal in stays running longer but as soon as i let off it dies. what the hell is wrong. i really need help on this. i need my car for a trip in about a month. my sanity rest on it.
thanks alot, mikey
badasx
Car: black on black 240 sx
check ur fuel filter and fuel pump my car did the same thing and thats what i did now it works if not that then try dumping ur cat
formalyDSM
sweet thanks i hope thats it
formalyDSM
badasx wrote:check ur fuel filter and fuel pump my car did the same thing and thats what i did now it works if not that then try dumping ur cat
replaced the fuel filter now it only revs to 2500 rpms and goes no higher. and still if i let off the gas it still dies
Soravia
Car: 2003 Audi A4 1.8T
Is your idle set right?
formalyDSM
don't know
WWJD
any check engien light? take a look at your MAf. my car did the same and turned out to be one of the ground wire's broke off.
formalyDSM
no check engine light
driftneil
Car: A pile of cars.
vacume leak....check your intake tubes if you have an aftermarket intake.
austin9888
hey man im having the same problem i think its a vacum leak but if you fix yours leme no im still looking for the fix
formalyDSM
austin9888 wrote:hey man im having the same problem i think its a vacum leak but if you fix yours leme no im still looking for the fix
it's fixed it runs, moves and goes to redline. look for a vacume diagram make sure all of them are hooked up to the right spot. on mine a few were not hooked up or in the wrong spot. she purs like a kitten now.
