KA24E MAF Wiring Question
fallen180sx
Car: 90 Sil80
how do you wire the ka24e maf on the ca? the kae maf is 3 prong, and the ca maf is 4 prong.. so obviously i need to wire the kae maf plug on the ca.. i just need a wire chart. OR is it the same guide as the z32 chart? thanks.
pulsar gtr
Car: NISSAN VEHICLES
KA24E --------------> CA18det black --------------> black black/white -----------> black/white White -------------> Green/black \\\\\\\\\ Green/yellow don't connect
PULSAR GTRRafi
fallen180sx
Car: 90 Sil80
thanks rafi! maybe a mod should sticky that guide.. i looked all over and sean needed the info also, (needcafors13) thanks!!!!!!!!!!!!!!
Modified by fallen180sx at 9:59 AM 3/27/2005
float_6969
Done...
sdtouge
Car: 1990 240sx coupe
sick. i just usd that. rafi, you made it super easy lol
float_6969
Rafi
pulsar gtr
LOL, you are all welcome, I am glade it helped.
RafiPULSAR GTR
fallen180sx
Car: 90 Sil80
alright, i hooked it up.. and it runs crappy.. i have to repeatidly tap the gas to get it to rev up and go.. i checked for boost leaks.. none. (me and my friend have a boost leak tester) so i guess its the MAF.. any suggestions?
fallen180sx
Car: 90 Sil80
also it runs extremely rich.
biosehnsucht
can be fuel, air, or spark.
test the coilpacks per FSM, also check the spark plugs.check the MAF per FSM.and for fuel, are you using the stock FPR? do you ahve a stock or aftermarket fuel pump? my walbro 255 lph made it hidiously rich (1900ppm AT IDLE of HC's) since the FPR couldn't keep up.
fallen180sx
Car: 90 Sil80
everything as far as fuel and air is stock. im using the stock KA fuel pump, and stock fpr. This MAF was old and real dirty when i got it. Ill check the plugs tho and the coilpacks are firing. Im getting fuel because im running def rich. My guess is either i have a leaking headgasket, or the maf is broke. The leaking headgasket theory is because im also running hot after a bit of driving.
Loofee95SE
Car: u gota sister??
sound like dead coil to me.... does ur engine shake alot? u seem to have a lot of problem with ur CA, is thats why u are trying to swap it for another S13?? are u still selling it?? C
fallen180sx
Car: 90 Sil80
ok guys, heres the story.. i just got a new s13.. 91 chamagne color. nice car, 300$. Im pulling the CA out of my coupe and while its out replacing the headgasket and a few other things thatll be easy to do while its out. Ill let you guys know the story when its done. thanks. it might be the coilpacks tho, because i remember a while ago one was going bad. thanks tho, ill keep you guys posted.
