ka24e maf
cocolo
Car: s13 sr20det
I need a maf urgently and in the search i found that i can use the z32 or the ka24e (sohc) mafs. for the z32 i found that i need a computer upgrade, but for the ka24e one i dont know. i need to reflash the computer for the ka24e maf?
i will appreciate any help
S13240
All you need is the ka24e maf pigtail(plug and some harness to rewire to your sr harness replacing the sr maf plug). Runs perfectly after that!
Blown240sx
Car: 1996 240sx
the DOHC has worked on my swap before. SO either SOHC or DOHC from S14 should work. Just look up the diagrams. I believe Jim Wolf's website has them all.
xero1
Car: 08 Altima Coupe
ka24e works like an sr20det maf, but i did noticed on a ka24e maf my a/f is 14.2 at full throttle with a stock s13 sr20det blacktop, stock 7 psi boot. is this normal?
Blown240sx
Car: 1996 240sx
its a little lean but not much. I think the SR is supposed to run like 13.4 or 13.5 as a good A/F.
niSssEanR
Car: 1992 b13 SE-R
I know this is for RWD, but i got a b13 se-r. I was curious if the ka24e would work on mine? i was thinkin it would since the ka24e and sr20det are the same. but i dont know how diff they are from a sr20det to a sr20de. i've searched here and this forum. But i only have acess from work, so i can spend to much time. I didnt find anything in my searching process.. can you help with this. Thanks alot guys.
