float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Wed Nov 03, 2004 8:37 am
Just as Nunook said. It's not needed. If you'd like, here is the reason that it is there...
When they first stared producing the S13 with the KA24E in 88' (sold as an 89' model year) They actually came with lower compression pistons than what most of the S13 KA-E's came with. During that time they used a simpler version of their ECCS system to control the engine functions. The problem was that later that year the US started imposing regulations regarding emmisions and such. Because of this, Nissan had to start using things like the EGR, AIV, ect.. These items cause the power to drop, so Nissan had to increase the compression and more closely monitor the A/F to get the same power out of the motor. This is the reason for the intake temperature sensor on MOST of the KA-E airboxes.
Nunook, it would be possible to do this, but would require some minor cutting of the intercooler piping. You would also have to find out what the resistance:temperature ratio is, but that could be easily found in a 90' FSM for the S13. The hard part would be to devise some sort of computer that would be able to sense the resistance, convert that resistance to a temperature value based on the graph in the FSM, and then display that temperature.
