aznpinoymike »
https://forums.nicoclub.com/aznpinoymike-u64176.html
Tue Feb 03, 2009 10:03 pm
Ka24e '90 s13 110,xxx miles
I recently just replaced my timing chain, guides, water pump, and tensioner because I had a tapping noise in the front of the motor. I put everything on the way i took it off and put it at TDC.... i go to start my car and a loud tapping noise occurs. I put my ear near the valve cover and I believe it's coming from under it. The car idles normal and it seeems to be running fine with the exception of the loud tapping. I'm not sure if it's my lifters or if my oil pump ain't pushin oil to my valves(still using the same old pump, should of replaced with a new one.. bad call by me) or if the car is off a tooth or 2 from TDC. Please let me know your ideas because I have a month to get this car on the road again before I leave for basic training next month.Thank you for your time
