KA24E + KA24DE Question
Punk21790
Car: 1990 240sx
Will the KA24DE head, intake and exhaust manifold bolt onto the single cam block and bottom end??
tk240
Car: 1990 240sx
i wanna know the same thing ive seen it questioned somewhere but never found the answer
Punk21790
Car: 1990 240sx
i see.. well i have a 1990 pignose with the single cam. i was gonna buy a crank kit because i found out the bottom end was destroyed. But since i already have the whole engine tore down i figured out id ask to see if it was possible. i might just find a dual cam and do the whoile sawap... im not sure yet.
tk240
Car: 1990 240sx
yeah tht sux but wht u know i have a 90 pig nose too its a hatchback is urs?
Space Monkey
Car: 1990 Nissan 240sx
If im not mistaken there are other threads on this as its a power upgrade. If you match a SOHC bottom end with a DOHC top end it raises your compression to like 13:1. Makes a high compression KA.
tk240
Car: 1990 240sx
where are these ive searched i havent seen them
Space Monkey
tk240 wrote:where are these ive searched i havent seen them
Search Archived materials:
zerothread?id=216808
Punk21790
Car: 1990 240sx
to your q about bodystyle. yes its a hatch and i plan on taking out the pig factor eventually. btw thanks for the link man... but im not sure i want to run 13 to compression on stock pistons i might mill pistons and use thicker head gasket to get it down to like 10.5 - 12 somewhere.
Space Monkey
I was off a bit. Looking through posts and other areas its only about 11-11.7:1 compression. My bad!
