KA24E, KA24DE, or CA18DET?
Discussion forum for the venerable 510, and its non-US counterparts, the Datsun 1600 and Bluebird.
azzkicker161
Car: 1969 510 datsun
im looking for a low budget engine swap. which engine would be easiest and cheapest to install in a 510, a KA24E, KA24DE,or a CA18DET?
Da5dime
Car: 1971 Datsun 510
I have a feeling no matter what you do you are going to be spending some money for a swap, but the cheapest way to go would probably be a KA24E. The parts are very available and those engines are found in the junk yard quite often or if someone is doing a SR swap then they are sold pretty cheap. The DE will be a little more cash, and a CA, well I just spent 1200 for the whole set-up. Its not that bad but there will be a lot of money being spent on my end. It might not be that bad if you are going to drop it right in. Lastly, it all depends on what you want you want your car to do. I would give you a little more info on KA's if i could but I have not done too much research on them. Good luck with what you choose to do!
tRQmnsTR
Car: 1971 Datsun 510, 1989 Toyota Supra
1993 Nissan D21
VG30e. No, not VG30DETT i mean VG30e. Shure it's N/A but, if you ever decide to go turbo, SR's and KA's will be no match. If I do my calculations correctly, my swap came out to about $1,200 +/-$100 http://teamthump.com/ Jeff will answer all your questions. Believe me when I say the VG30e is an underrated engine, you won't be disappointed.
Boosted 70z
Car: 70 datsun 240z
I want vg 510, it just sounds mean , especially if theres kits to bolt them end. They're cheap motors too. If you do go that route, make sure you have a new timing belt.
tRQmnsTR
1993 Nissan D21
Boosted 70z wrote: I want vg 510, it just sounds mean , especially if theres kits to bolt them end. They're cheap motors too. If you do go that route, make sure you have a new timing belt.
Hahaha. I did my Belt, thrmo, and water pump at the same time. Yo you can also buy custom headers from VG30.com. And Boosted is right that **** sound so mean
Return to “Datsun 510 / Bluebird”
