is doesnt do any of this... and it only happens when i am cruising down the street or something.... i dont think its the clutch but ill look into thatthanks12Ounce wrote:While using the engine to "brake" the vehicle's speed, or coasting; its possible to have this experience if the clutch is worn and slips.
But if the clutch is worn this much, you should also experience slipping as you accelerate or pull a hill. In this case, the engine rpm would jump upward.
