mutiny »
https://forums.nicoclub.com/mutiny-u53418.html
Sun May 20, 2007 9:08 pm
Finally got my motor pulled out, and onto an engine stand, and am beginning to start ripping the block apart but kinda ran into a small problem. The intake manifold will NOT come off.
I have removed all the bolts, (2 bolts and 2 nuts upper, 2 long bolts in between the runners, the 1 bolt hidden behind power steering pump, and the entire manifold stay is removed from the block). I'm positive I got all the bolts, unless the FSM is missing one in the diagram.
I've tried prying, hitting it with a mallet, turning the motor sideways on the stand and literally hung on the manifold. I got the left portion to come loose, but the right half seems like it's stuck on something. Could it be that I bent the stud or something, because I did wrap a chain around the intake runners in order to pull the engine out of the bay. Any ideas?
