Ka24e Ignition
TrueDrifter
I replace the wires with Nology HotWires what can i use to replace the coil?
S133P3R
Car: 1989 S13 240sx
MSD blast coil 2 with ballast?
TrueDrifter
I replace 22434 with Blaster 2?
Modified by TrueDrifter at 1:59 PM 12/31/2008
S133P3R
Car: 1989 S13 240sx
i dont see 22432 on the diagram u posted. i think the MSD blaster 2 coil replaces 22434.
TrueDrifter
my bad 22434, What about a MSD-6AL Ignition Control set up?
S133P3R
Car: 1989 S13 240sx
sorry. cant say ive looked into those systems. I upgraded my wires to magnecore spark plug wires and was looking at the "blaster 2" cuz it was under $100 USD.
TrueDrifter
thinking about the blaster 2 its only 56USD, now the problem is installing it the old coil has a 3 pin plug
S133P3R
Car: 1989 S13 240sx
let me know how that works out for you cuz i never bought one.
wa-chiss
Car: 1990 Nissan S13 H/C KA24E
2005 Toyota Sequoia
1976 Honda CB750F Super Sport
TrueDrifter wrote:my bad 22434, What about a MSD-6AL Ignition Control set up?
An MSD-6AL is a sinch to hook up. You're not going to get anything out of a blaster 2 unless you increase the voltage to the coil. Which is the main thing the 6A/6AL does. At below 3k rpms, it puts out multiple sparks. But, after 3k, it only puts out 1 spark at a very increased voltage. The only thing I see a Blaster 2 coil benefiting you without the 6A/6AL is shorter recharge time.
I did a write up on installing a 6A box on my SOHC. The 6A and 6AL are exactly the same only the 6AL has a limiter function (hence the "L")
zerothread?id=317445
wa-chiss
2005 Toyota Sequoia
TrueDrifter wrote:thinking about the blaster 2 its only 56USD, now the problem is installing it the old coil has a 3 pin plug
Nope, it's only 2 wires. At least it should be. Make sure you're not looking at the ignitor (P# 22020N in your diagram). It sits less than an inch away from the coil and if I remember corectly, IT has 3 wires. Coils have a positive and negative only.
