KA24E Ignition Resistor
jimmer84
Does anybody have the resistance value of the ignition resistor(the one taped up by the condenser on the harness).Ours is missing and need to get one. It's in a 1989 240sx and has no spark and trouble code 21. Any ideas? Checked coil, transistor, crank sensor and ecu. The ecu is not sending a signal to the transistor to fire.
ThanksJim S.
mutlah
Car: S-13 with 93 KADE 1.0 mm oversize bore
Hi, I came up with 2.19 thousand ohms through mine. I have code 21 as well and have checked everything too. Still unsure why. I have followed my schematic and made notes along the way. Keep trying!!
neverlift
typically the power transistor is the culprit in a code 21, in my experiences
