locoluna825 »
https://forums.nicoclub.com/locoluna825-u93365.html
Fri Jun 19, 2009 6:01 am
whenever you rip the head off a sohc they always get noisy, sometimes something can get into one of the oil channels from taking it off and travel to one to the tappets after being reinstalled, the rocker assembly is supposed to be bled.
when i took my head off it was noisy as hell and i couldn't stand it i experimented with different types of oil (thick oil works good) and did like 4 oil changes in a month. i kept taking the rocker assembly off the head messing around with it trying to get it to quiet down. but i eventually went to a pick apart ripped another head off another 240 and stuck the rocker assembly onto my car.
it was much more quiet but still had one or two taps coming from the head but eventually i guess it finally bled itself out and went away. its very quiet now.
As for the high idle, if your battery was unplugged for a while it might have cleared the memory on your ecu, i believe a cars idle is adjusted according to altitude. and with the ecu wiped form being unplugged from the battery it looses that memory, I live in a higher altitude area, about 4000 feet above see level. and i had wiped my ecu on purpose, then the idle was very low, so like u i adjusted the idle so it would be normal. with in a week of driving it around, the car started idling really hi so i adjusted it back and it was idling normal with it back to what it was.
another instance of this was when we tried to smog a friends ford ranger. the car was throwing and engine light. so we thought we would be clever and unplug the battery, clear the memory on it and get it to the smog guy before it came back on. well the smog guy couldn't smog it. He told us (from what he had described) " the ecu had not calibrated itself yet" we asked him what he meant and he knew that the ecu had been cleared and it wouldn't even pass the smog test because now the exhaust was spewing out more co2 than it should have been. he told us to "just drive the car" like at 55mph or more, so we did for a couple days the engine light came back on after that so it didn't pass visual, but it did now pass the smog part.
my overall suggestion is to make sure your setup is all correct, get a timing light and make sure its dead-on. put the idle screw back to where it was. Run some thicker oil in that thing and get some highway speed miles on it for about 30 minutes. and just drive it around town
Modified by locoluna825 at 9:14 AM 6/19/2009
