wtf. How does this have anything to do with what he is asking?neverlift wrote:here is the thing... you use a de head/block/intake/exhaust/ecu/sensors,then throw a set of 90 pistons in that motor, or if you have a bit more balls and wideband you can do the 89 pistons but you may encounter problems...good luck in anything you decide
did you read his post?Quote, originally posted by neverlift » here is the thing...you use a de head/block/intake/exhaust/ecu/sensors,then throw a set of 90 pistons in that motorstealth_180sx wrote:wondering if this is possible? and wat other parts r needed besides the head?
