How do you check used injectors to see if they are good or bad??
Would you reuse injectors?
Post by racingchick19 » https://forums.nicoclub.com/racingchick19-u157325.html Wed Jun 30, 2010 8:18 am
Post by Klits562 » https://forums.nicoclub.com/klits562-u133972.html Wed Jun 30, 2010 4:51 pm
Ya you can reuse injectors just make sure you replace the o-ring or seal on the tip of the injector that goes into the block.racingchick19 wrote:How do you check used injectors to see if they are good or bad??
NICOclub's Nissan forums and Infiniti forums and all affiliated sites are the property of HDS Holdings, Inc.
They are independent publications and are not affiliated with or endorsed by Nissan or Infiniti.
Information Copyright © 2000-2026 by NICOclub, all rights reserved. Material may not be copied or reprinted without written permission.
