I was about to adjust the "idling Screw" on my 1990 Nissan Pickup, when I suddenly noticed that the engines RPM's increased. I went and "wiggled"
the wire on the IACV, and the engines RPM then dropped. I found out that this IACV was faulty and causing the engines RPM to go up and down. But in the process of doing that the wires must have shorted out, because the terminals on the" idle air control Valve" turned RED HOt
at that same time the Positive battery terminal arched and the engine cut off. I checked the headlights, interior lights the horn and they all worked, except for the ignition. When I turn the key to the "Ignition" all it does is,.......
NOTHING!!!!!. Can anyone help me out with this problem ?
Thank You
Maximum RPM
