zerepdivad »
https://forums.nicoclub.com/zerepdivad-u34747.html
Sun Aug 31, 2008 5:32 pm
We had a similar problem with my friends sohc. Turns out his connectors in the injector clips were very loose and corroded and were not making good contact anymore. Most likely from people improperly removing them and yanking by the wire as opposed to the plastic connector.
We ended up just getting some little electrical connectors from my work that would fit right on each prong in the injector and cut the clips off and dirrectly wired them in and it worked fine.
