KA24E ENGINE
RIPCAT
Car: 1990 240sx
I have a 1990 240sx SE and need to swap my motor. I am just doing a KA24E engine (same as what I have now). I was looking on Ebay for an engine and found quite a few for the Stanza and Axxess, they're KA24E engines but was wondering if they will still fit in the 240? For example, do I need different engine mounts or anything? Or will it just be a staight swap.
Again, I am only diong a KA24E swap, SOHC. So please dont leave posts giving me reasons on why I shoud switch to DOHC or SR20DET or w/e else,THANK YOU!!!
Any info on this will really help me, I miss driving my baby!!! ~RIPCAT
airman86
i'm not an expert on these cars (yet), however i wouldn't imagine any modification necessary. a ka24 is a ka24. the only thing i might think you would have to do is change the accessory brackets (like ps/ac) would need to be thrown on from your current (assuming screwed) engine.
i say this from experience, i bought a 4g63t from japan and had to change over the power steering bracket from the one i was replacing. some motors can be different I guess, but the mounts should be the same.
don't take my word for it, hopefully someone can confirm that. i'm just speaking from my experience in motor swaps, at least same engine codenames from different car models.
RIPCAT
Car: 1990 240sx
Thanks for the info, that's what I was thinking too. Hopefully more people will post info to confirm that soon, I wanna be driving her again shortly!
Vegascorbin
Car: 1990 240sx dirt track race car
If you are swaping KA24E for KA24E then everything should go right in. Just be sure to clearly mark everything when you disconnect so you can re-connect properly.
Helps to have a friend around to help watch while you put the engine in and out.
killbillet
Car: 1996 nissan 240sx se
motors are the same. you will be good getting a fwd ka
RIPCAT
Car: 1990 240sx
killbillet wrote:motors are the same. you will be good getting a fwd ka
It doesn't matter that my car is RWD?
airman86
iirc, the motor will just be turned sideways instead of longitudinally.
H8HONDA
Car: 89 240 sx KA24E
hey man i just did the same swap in my car single cam for single cam and the one i swapped in spun a bearing 150 miles later. so i would suggest finding another single cam and rebuilding it from the ground up using stock parts of course nothing expensive. thats what i am doing now. i tore the whole block apart and took it to a machine shop. and here is what hes doing and the cost. clean block, replace all freeze plugs with brass ones, grinding the crank(#3) journal was destroyed., i am having it bored .020 over just because the #3 hole was a little messed do to vibration. reconditioning rods, and rebuilding the short block for me.all that is costing me is like 650 im getting him the parts because you can get them cheaper at a parts store than what they will sell them for. and like i said my advice is from personal experience. if you want to know anything else let me know im pretty good with single cam stuff. and only use another 240 engine all ka blocks are the same but some head stuff is different.
RIPCAT
Car: 1990 240sx
H8HONDA wrote:hey man i just did the same swap in my car single cam for single cam and the one i swapped in spun a bearing 150 miles later. so i would suggest finding another single cam and rebuilding it from the ground up using stock parts of course nothing expensive. thats what i am doing now. i tore the whole block apart and took it to a machine shop. and here is what hes doing and the cost. clean block, replace all freeze plugs with brass ones, grinding the crank(#3) journal was destroyed., i am having it bored .020 over just because the #3 hole was a little messed do to vibration. reconditioning rods, and rebuilding the short block for me.all that is costing me is like 650 im getting him the parts because you can get them cheaper at a parts store than what they will sell them for. and like i said my advice is from personal experience. if you want to know anything else let me know im pretty good with single cam stuff. and only use another 240 engine all ka blocks are the same but some head stuff is different.
Thanks for the info man, I am trying to get her running strong again and have decided to sell it once it is. I dont want it to crap out on the next person that gets it though, they should enjoy their new toy haha.
So only a 240 engine? I am having a really hard time finding any
any help or suggestions?
H8HONDA
call every junkyard you can find. and if you cant find anything try local forums or maybe your local street raicng or drifting scene alot of people will give you their ka for dirt cheap. i have 2 of them myself lol
