CJR04 »
https://forums.nicoclub.com/cjr04-u92351.html
Mon Jul 13, 2009 3:00 pm
I am working on my brother's car and it has exactly the same symptoms. It is running too rich (11.5 or less, read using a wideband O2 sensor) and it iddles rough.
I suspected the computer, after checking almost all the sensors and them checking OK. I have troubleshoot and found the same results as you.
The car had originally burnt a computer and a mechanic swapped it twice. I am using the ALL Data program to help me troubleshoot. I checked the computer #'s on the list that they provide for when you need to replace it and it corresponds to a 1991 car and my brother's car is a 1990 (2-90 production date)
I just got another computer that supposely is for 89-90 and swapped it but now the car runs worst. No codes. I will play with the throttle cable and the IAC as I had adjusted it before to try to solve the issue with the first computer.
With first computer and MAF disconnected, it ran better on iddle but still rich. With new computer as soon as I disconnect the MAF, the car shuts off.
Also, I could not extract codes from first computer as it had an LED missing and I could not even make the one left blink.
