KA24E EGR?????
jack-pot
I've searched the forums on this topic and everyone says that they are going to do a write up, but i havent found anything about removing the egr on a KA24E. I was wondering if the egr removal on a KA24E was the same as in Fiznat's write-up on the KA24DE? if so ill just do it like the write-up, but if not i was wondeirng what has to be takin off and what is supose to stay. and i was also wondering about all the people that say it throws the egr code (32) what would i do to get around that if it was to happen? thanks
Import_Ant
tomorrow tomorrow tomorrow... I took pictures a few mins ago. i'll get bored at work and finish the write up I started w/ pictures. it wont be as polished as Fiz's but it's a start.
214kka-et240sx
Car: nissan s13 silvia
it is ganna throw you code 32, and your check engine lite is ganna stay on the whole time, and there is no way to get it out of the ecu , and for the EGR, just take the valve off, make a block off plate and take off all the vacuum holes and the egr soleniod and you should be fine,
